Forum > General discussions > Non mobile discussion > Which 2.1 speakers to get? Pls help!
Author Which 2.1 speakers to get? Pls help!
Evil Eye
Aino White
Posted: 2008-08-09 08:11
as above.
I have rouded my choice to the following speakers:
1. Creative SBS A300
2. Logitech R20
3. Logitech X210
4. Altec Lansing BXR1121
Have you guys used/had experience with any of the speakers listed above?
Which manufacturer would you suggest?
Thanks in advance!
i-mate K-JAM and Windows Mobile Discussion Thread
Proud owner of i-mate K-JAM & Nokia N81
[ This Message was edited by: Evil Eye on 2008-08-09 21:21 ]
deepsme
G900 Brown
Posted: 2008-08-09 08:31
Have been using the SBS 370 for the past 3 years...find them excellent at both the bass and treble sounds...no distortions...and no trip to the service center either...don't know about the others but 370's are cheap and you get more than what you pay for with them..
You should also check out this one...
http://in.creative.com/produc[....]oduct=15970&nav=1&listby=usage
here, have a puff
Evil Eye
Aino White
Posted: 2008-08-09 15:49
bump!
Proud owner of Samsung Galaxy Pro, i-mate K-JAM & Nokia N81
arien617
Posted: 2008-08-09 17:03
BOSE Companion 3 or 5.
£280 for the 5, £200 for the 3. They're like nothing you will have ever heard before.
Evil Eye
Aino White
Posted: 2008-08-09 18:44
The speakers i have listed are budget speakers under 40USD.
Can't afford the BOSE speakers.
[ This Message was edited by: EviL EyE on 2008-08-09 17:46 ]
arien617
Posted: 2008-08-09 19:00
Narr, neither can I :/
The sound quality is simply amazing though!
Evil Eye
Aino White
Posted: 2008-08-12 15:38
Thanks for all your help guys. Finally bought Logitech X210 after reading all the positive reviews
