Shutter speed |
Laurier Joined: Jul 03, 2005 Posts: 21 PM |
Have searchd the forum but could not find it.
I find that the shutter speed of the k750i i have i much to long!
The slightest movement and the picture is blurry :s
Is there any way to shorten the shutter speed or is that improved with new firmware? i'm still running the old one.
m100 Joined: Aug 12, 2004 Posts: 189 PM |
Try holding the phone steady.
This message was posted from a K750 |
heckcare_der Joined: Jun 24, 2005 Posts: 27 PM |
try the new firmware. R1L. after i change, it works well for me. |
sometimes holding the phone steady isnt easy.
I shot some pictures at a party this weekend and a lot of them where blurry caus i was drunk.
And shooting a pictures of somebody doing a trick for exaple is impossible caus his movement is blurry.
Did it change a lot with the new firmware? I still wast able to update it myself but i am going to go to a shop to do it. |
tzakiel Joined: Sep 29, 2004 Posts: 66 PM |
Like all camera, ever, the more light you have the faster it exposes the picture. Turn on more lights, and stop using night mode to compensate.
You'd find the same exact thing happens with a quality SLR film camera in indoor light which is typically very low. |
sunfury Joined: Jun 24, 2004 Posts: 63 From: Istanbul PM |
You can also change the exposure compensation setting betveen 0 and -1 in order to get faster shutter speeds.
But be careful, if you underexpose too much, the picture will loose some details in the dark corners.
[ This Message was edited by: sunfury on 2005-07-12 16:14 ] |
