Nokia contacts to SE k750 - possible? |
k0rrupter Joined: Jun 18, 2005 Posts: 55 From: NY / USA PM |
I've got my Nokia 3650, but now i've my SE K750i and i've got like 420 contacts on my Nokia and 400 messages. Is there any way i could put these contacts on my SE or do i have to it manually? A Sync manager or somthing.
Thanx |
EastCoastStar Joined: Dec 07, 2003 Posts: > 500 From: orlando fl US PM |
on your nokia... copy your contacts to your SIM, then on your SE, copy contact to phone from SIM.
Its good to be back! |
max_wedge Joined: Aug 29, 2004 Posts: > 500 From: Australia PM, WWW
yeah, you need to synch it somehow. If you have a pc, download the nokia and sonyericsson synch software (check their respective sites out).
Then you need to synch outlook with the nokia, then synch outlook to the se.
fu1at Joined: Nov 01, 2003 Posts: 325 From: Selangor, Malaysia PM |
As most me the SIM only allow 250 contacts can be store inside. So the best way still use syn. U might lost half of ya sms because k750 max sms storage is 200.
Ya thnx guyz, i'll probably go to what max_wedge said as in Nokia to outlook then outlook to SE.
Does the SE only have a limit off 200 msgs. Doesn't it depend on the memory card, and r the msgs stored on memory card or phone memory?
thnx again! |
Phantom Joined: May 19, 2005 Posts: 335 From: Sugar Land, TX PM |
all i did was just send business card one by one... surprisingly it was WAYYY faster than i expected it to be. |
nope.... K750i not a smart phone that why it has limitation on sms storage. u have to remember nokia 3650 is a symbian smartphone platform.
 J200, W550i, K750i, M600i, HBH-30, HBH-660, HBH-608, HBH-PV700, HBH-610, MXE-60, CLA-60, MMC-60, CDS-60, |
mmm100 Joined: Jun 18, 2005 Posts: 4 PM |
hi guys ..
can anybody tell me exactly how to copy the sms from nokia to the sony ericsson using the synchronisation ?
and can i put them into the memory card or not ??
thnx alot  |
k750 is atleast 500 contacts. Make sure you are using the phone address book and not the sim card address book (which is limited to 200) |
