K750 - Adding Shortcuts to the Activity Menu |
albertmctam Joined: Aug 17, 2003 Posts: 11 PM |
Hello folks. Is it possible to add shortcuts to the K750 activity menu? So far I've been able to move and delete shortcuts from the activity menu, but not add to it. I've read the K750 user menu but found no instruction on how to do it. Any idea?
Regards,
--Albert
[ This Message was edited by: albertmctam on 2005-06-16 19:28 ] |
bolo Joined: Jul 12, 2003 Posts: 90 From: Soton PM |
you can add shortcuts if you go to the last entry on the activity menu |
Phantom Joined: May 19, 2005 Posts: 335 From: Sugar Land, TX PM |
if you press activity menu, then scroll up one, you'll be on "add shortcut" |
meeezz Joined: May 27, 2003 Posts: 71 PM |
Just press the add shortcut button and the menu will pop-up, select whichever icon you like and press the shortcut key, it will be added accordingly, should you want to move the shortcut key up or down you may press on the "more"button. |
