Will the size of animated wallpapers be larger if the original pictures are JPG's? |
MobileVisuals Joined: Mar 24, 2005 Posts: 38 PM |
The original pictures for my animated wallpaper are JPG's. Then I use JASC animation shop to convert them to GIF's.
Would it better to have the original pictures as GIF's from the beginning, so JASC wouldn't need to convert them? Would the resulting GIF animation be smaller then?
blayv Joined: Oct 24, 2004 Posts: > 500 From: Srbija PM |
maybe better quality. dont' think it woul be smaller
ThreeX Joined: Dec 21, 2002 Posts: > 500 From: Sweden PM |
I donīt really think it would matter.
Animation shop manipulates even .gif files to make them smaller in size and load smoother so..
Happy owner of: Ericsson GH198, S868, SH888, R310s, T10s, T28s, A2618s, T39m x2, T68m, T66, SE t68i, T610, S700i, Nokia 2110i, 6210, 8310, 8850, 8890 and 6680 Siemens S55 |
No, I meant he it were gif from the start it would have been crisper cause gif looks better than jpeg .
This message was posted from a T610 |
How can .gif look better than .jpeg when it supports only 256 colours??
Jpeg is blurry compared to gif. If you make gif->gif you won't loose colors.
Cycovision Joined: Nov 30, 2003 Posts: > 500 From: England PM, WWW
Yeah, the Jpeg's have already been compressed so you're effectively taking an already relatively low quality image and reducing the colour depth to make it even more low quality. You'd be better starting off with raw bitmap images.
Of course, the thing about gifs is that it depends very much on what the image actually is. If the raw bitmap naturally doesn't use many different colours and shades then the gifs will look much better.
OK, there is no use in using original gifs instead then I guess. The problem that I have is that my customer MediaPlazza requires that most of the animated wallpapers should be less than 15 kb. It seems impossible to make them that small and still look good. I am using JASC animation shop and even if I only use 5 frames and optimize it as much as I can with the optimization wizard, the wallpapers become too large.(about 20 kb) How can I make the wallpapers smaller? This is one of the pictures I am using in my wallpaper:
It's the graduated fills that are causing the problem. I doubt very much that you'll get a small gif file size from that base image
The only way would be to change the base images to use less colours in the first place by not using graduated shades.
You were right. When I made the pictures less detailed the gif-animations became much smaller! |
