V802SE/Z800 Bluetooth > PC Help. |
BBHo Joined: Apr 01, 2005 Posts: 3 From: Australia PM |
I recently bought a V802SE from Hong Kong. To my knowledge it is a 3G phone from Japan. I have managed to check the Software info and it says "R1x019, prgcxc1250048_Hong_Kong_Vi". When i search for bluetooth devices on my computer with my bluetooth program "BlueSoleil" it finds a mobile device "Z800".
My Problem is, despite being able to detect the existance of my phone, i am unable to connect to the phone itself. I am eager to upload my phone contacts from my Address book to my newly bought V802SE/Z800 but the package i bought did not include any software or USB Cable. My guess is the only way i can upload my contacts is via bluetooth, however after searching the Sony Ericsson site im unable to find any software/drivers for the Z800 bluetooth on PC. What can/should i do? Thanks in advance. |
sevastos Joined: Dec 08, 2004 Posts: 105 From: Karpathos-Greece PM, WWW
Try these drivers here: http://premium1.uploadit.org/sevastos//Z800-drivers.zip
I'm not sure if it works with the but it works with the cable... Let me know |
tjetja Joined: Mar 23, 2005 Posts: 9 From: Indonesia PM |
Try using WindowsXP with SP2 installed. Many advanced BT services was improved there :)
This message was posted from a T39 |
boogah Joined: Jan 21, 2005 Posts: 16 From: Honolulu PM, WWW
I wasnt able to do it with my PC at work (WIN 2K) and when I did it at home with SP2 (XP), it worked like a charm. Good luck mate! |
Thanks alot for the help. SP2 for winxp solved everything. |
