Forum > Sony Ericsson / Sony > GPRS, WAP, MMS and Email setup > Free sms via gprs?
123  Next
Author Free sms via gprs?
Evil Eye
Aino White
Posted: 2005-03-31 21:05
I heard that there are some settings done in a se phone after which 1 can send free sms using gprs in hutch.Can u lemme know the settings?
whizkidd
W950 Blue
Posted: 2005-04-01 06:12
I did try it, but it didn't work.
Evil Eye
Aino White
Posted: 2005-04-01 07:01
satan89
Posted: 2005-04-01 07:07
It used to work on hutch but now it says 'message failed'.
whizkidd
W950 Blue
Posted: 2005-04-01 07:10
Some guys on airtel were able to do that. But not me.
Evil Eye
Aino White
Posted: 2005-04-01 07:14
But still can u tell me the settings,i will try.
Evil Eye
Aino White
Posted: 2005-04-01 07:48
Hey please tell me the settings.
mrao
Posted: 2005-04-02 06:00
Manish...go to Data Communication> SMS Access & select the GPRS option. I've tried it on Airtel and it works fine...( I think & hope its fine)..I'll know for sure when I get my bill...If there are no charges for the SMSs 've sent ...i guess it works
<br />
Still Shiny but not so n
whizkidd
W950 Blue
Posted: 2005-04-02 06:51
Someone on prepaid should be able to tell.
clank
Posted: 2005-04-02 08:14
I used it about a year and half back on airtel prepaid...in 3 months i had sent free messages running in thousands but i then they wised up to it and it abruptly stopped working. This was with a nokia btw. It has never worked for me with hutch prepaid so i guess they have already made amends to prevent such misuse.
nitesh
W900 black
Posted: 2005-04-02 08:56
Hey guys does this work on T610 ? Because there is no settings for sms in data commu !
govigov
K500
Posted: 2005-04-02 09:05
I thought it did work for me. But the airtel's balance info was messed up at that time.
This message was posted from a K500
nitesh
W900 black
Posted: 2005-04-02 09:12
What about the settings for T610?
mrao
Posted: 2005-04-03 05:23
Nitesh...what do you mean no option for sms access in T610
Check data communication...should give you 3 options....1) data accounts 2) preferred service 3) sms access
select sms access...should give you 2 options a) GSM b) GPRS...try selecting GPRS.....if you are on Orange prepaid....forget about making this work....Airtel prepaid...i dunno...worth a try
<br />
nitesh
W900 black
Posted: 2005-04-03 05:30
I just have only one option data accounts:-(
