mail forwarding to mobile |
radarblip609 Joined: Dec 12, 2004 Posts: 107 From: Pakistan PM |
My mobile doesnt recieve the email that ive set to forwarded to it as SMS through gmail, hotpop etc. Anyone knows what the problem can be? |
govigov Joined: Jul 30, 2004 Posts: > 500 From: Back home - Cochin PM |
Use www.bluebottle.com and see.
This message was posted from a K500 |
Isnt bluebottle the one which accepts mail from only known contacts? If it is the same one then i think it does not have the forwarding option.
This message was posted from a T68i |
MaxHeadroom Joined: Dec 17, 2003 Posts: 32 From: Sweden PM, WWW
i didnt know gmail could be forwarded as an sms? if so, tell me how.
//MaxHeadroom Rehab is for quitters |
This is the way to fwd mails from gmail to sms: some mobile operators give you an email address. When email is sent on that address, it reaches you as an sms. So in gmail options,write this email address in the forwarding option. There you go. But this is not working for me. I can get mails normally on my this address but cant get any forwarded mails.
