Bluetooth Add On |
lowghost Joined: Mar 01, 2005 Posts: 14 PM |
Is there like an accessory for the K500i where it gives you bluetooth, where you can send anything or will I have to stop dreaming? |
whizkidd Joined: May 14, 2004 Posts: > 500 From: India PM, WWW
I think you'd have to do the latter. :-)
This message was posted from a T230 |
yeah but is there an add on? |
mathios Joined: Feb 24, 2004 Posts: > 500 From: greece PM |
look at this l have one but l don't know if it's still available try a search on e bay or google. http://www.sonyericsson.com/s[....]s1_1&zone=ps&lm=ps1_1&pid=9594
__ _______________
μην ψαχνεις να αγαπησεις κατι τελειο... αγαπησε κατι που δεν ειναι τελειο,και καντο τελειο με την αγαπη σου....
[ This Message was edited by: mathios on 2005-03-07 15:13 ]
[ This Message was edited by: mathios on 2005-03-07 15:15 ] |
govigov Joined: Jul 30, 2004 Posts: > 500 From: Back home - Cochin PM |
Whats that? I'm on phone and cant click that.
This message was posted from a K500 |
get on line and see,it's a sonyericsson genuine acseccory for non bluetooth devices.
But if you click the compatible phones link, its only compatible with the majority of mono colour screen SE and Ericsson phones.
So no K500 support AFAIK.
Buy a cheap K700.
mrao Joined: Nov 11, 2004 Posts: > 500 From: Mumbai, India PM |
@ghost..i would take etaab's advice and just go for a cheap k700
 t610 > k700i > p800 > p900 > p910 > k750i > I-mate Jam > Blokia 6681 > HTC Prophet > HTC Wizard & Nokia N73 > E71 > BB 9000 > HTC Desire > Samsung Galaxy S > Samsung Galaxy S II & the Motorola Xoom <br /> Still Shiny but not so n |
I was really lookin forward to it.
it also works on your K500.
however the bluetooth unit installed in the acc. is old and could not be stable.
i believe some oldies here used it with there T300 and it work fine, but thats along time ago.
it works with all sonyericsson phones l have tried it the only phone that had an instabillity issue was the t200 and l updated the firmware and it was solved.
@mathios and bart, thank you. i will be looking for one...
@bart, if you have one, i will be more than glad to buy one
Works with the T230?
yes whiz, it can be used as a blue tooth modem tooo...
jagger2k Joined: Nov 14, 2004 Posts: > 500 From: Leicester, UK Phone: IPh PM |
so how does this work then? does it bring up a menu in the conectivity menu? also is there one which is smaller in size so it dont make your phone look big if you take it out and about. |
