service menu in 902sh |
Hi!
I know with S-E's, I can access the service menu with
service menu by pressing >*<<*<*
Is there a way to do this with the Sharp 902sh?
Thanks!
ofiaich
Merovingian Joined: Aug 29, 2003 Posts: > 500 From: Norway PM |
QUOTE
well, heres how you put the code in if you already have the code...
With your Vodafone simcard inside the phone type this code: *01763*6371#
Now press the menu button.
Scroll to "Settings" and press SELECT
Scroll to "Security" and press SELECT.
Scroll to "Mep locks" and press SELECT
Enter your handset code (9999 is the default code) .and press OK.
Scroll to "Network" and press SELECT
Scroll to "Deactivate"and press SELECT
Enter your given code and press OK.
The handset should then say Done.
Your phone is then unlocked and the MEP Locks section dissapears.
Hope this helps.
Try that, BUT AT YOUR OWN RISK
Thanks Merovingian! .
This seems complicated! ... as compared with accessing the secret menu's on S-E's!
You mention the 'code'! I do not have an unlocking code from Vodafone.
I am wondering how to get into the menu that shows things like number of joystick presses etc!
Is it the same as what you are telling me?
Ofiaich
