Problem with size of .jar-files during upload!Please read! |
PsyCh0therapy Joined: Jan 31, 2005 Posts: 3 From: Greece PM |
Hey guys!I need your help badly!
I have a usb cable and programm from Vodafone and when i try to upload "Splinter Cell Pandora Tommorow.jar" on my K700i there comes a message that says that i cant upload it because its size is bigger then the allowed size of .jad-files(256 kb)
Do you know a way to put the game on my mobile?Is there any good programm whithout size limitation?
Please help
Greetings from Greece
Vlammetje Joined: Mar 01, 2003 Posts: > 500 From: Den Haag PM, WWW
if you have the usb cable, can't you just 'drag and drop' without bothering with a transfer program?
Nope it only goes through the programm!Anyway i just found out that the k700i-SpCellPandora version is smaller (about 180kb) so I dont have a problem with the limit!Problem is solved then!Thanks everybody!And check my post at the 3d games,i gathered 3 great links! |
