Help wanted please (data cable + t68i related) |
Serial Joined: Jul 09, 2002 Posts: 4 From: Liverpool UK PM |
I bought this data cable + software pack :
http://www.matweb-01.com/English/eng-products-cable.htm
All works fine with the software provided, however it's limited cos it's more t68 software based. Also i can only transfer the low quality bmp's and not the high quality (which i really want to be able to do).
I want to be able to use ericssons Mypicture program, however i cannot. The XTNDConnect PC will not install it gives me some grief about me needing outlook running and that i should purchase the new software (which i have no intention of doing cos that might give me the same message).
I'm running on winxp.
Any help is appreciated - thx. | |
Froddan Joined: Jan 18, 2002 Posts: > 500 PM |
Yea, I had a bit of the same "problem" with my win98/outlook2000, serial cable and T68MMS.
In order to install XTNDpc, (I believe) you must have outlook installed and configured to a mail account. Anyway that did it for me. And now it works great.
But the only thing you really need for the image maker to work, is the mpm (mobile phone monitor), which can be installed separetly.
Hope this helps. |
AhH :| i have an outlook account configgured, i have been using outlook for years. DAmn  | |
