Sound of loose parts when you shake your T68? |
lesneo Joined: Jan 19, 2002 Posts: 482 PM |
Hi all,
when I hold my T68m near my ear and shake it, I can hear a loose part shaking. First I though it was something inside that was loose and was ready to send it in to SE.
Upon careful examination, I discovered that it is actually the slider (for volume control, view date and profile) at the left top side of the phone that is the "loose part" and making the "noise" when I shake it.
Is it just my phone or do you guys have such a "loose part" as well?
Please, please, I just gotta know... |
MarkOng Joined: Jun 11, 2002 Posts: > 500 PM, WWW
Its the volume slider, I've got the rattle too.  |
andreaze Joined: Jul 02, 2002 Posts: 91 From: PM |
I have that sound to... |
spanker Joined: Jun 24, 2002 Posts: 122 From: Melb PM, WWW
me too.... me three..... me four~~~~~~
 T68 R2E006  looking for a HPM-10 in Australia, messege me if u wanna sell me |
It's a relief to hear that this is a universal problem and that not of my phone only.
Shouldn't SE rectify thsi problem? It really makes the otherwise flawless phone "flawed".
Any views. Should we petition? |
I'm quite fine with it. Doesn't bother me that much.
kevin81 Joined: Mar 12, 2002 Posts: 390 From: Stockholm, Sweden PM |
Mm, mine too. But it's probably nothing to worry about since the phones are working correctly.
cadcad Joined: Mar 01, 2002 Posts: > 500 From: Lebanon PM |
It's very clear that this sound comes from the slide volume key and not from the internal parts. It's not a big problem as much as this key remains at its place.
This post was posted from a T68i |
