LCD problem on T68i. |
jac12 Joined: Feb 06, 2002 Posts: 89 PM |
I have a small LCD problem on my T68i. There is a thin white stripe from top left corner to bottom left corner. Seeems like the screen should be adjusted a bit to the left. Anyone else with the same problem or how to solve it? |
Thief Joined: Jan 11, 2002 Posts: 121 From: Greece PM |
I had this problem with a T68m but the stripe went away a few hours later. I think you should take it to a SC.
Th|eF |
evoke Joined: Mar 05, 2002 Posts: > 500 PM |
jac12> This is common in all the T68's I've had (and I've had a few) only in the service test display menu where a thin white stripe can be ssen on the left hand side. This (i beleive) is common to all T68's and not a problem! If however you have this white stripe in normal service (ie all the time) then you should take it back to where you bought it or to your neatrest SC to have a look at.
Ed
Thanks  |
No probs - which was it though just in the service display test or all the time?
Ed
I only saw the white stripe in the service menu, but on SMS messages the letters to the left seems like they are a bit cut off. It's no problem to read but it looks like it's more "space" on the right side. |
