how do you take apart theT68?? |
john74 Joined: Dec 21, 2001 Posts: > 500 From: GREECE/AUSTRALIA PM, WWW
except for the 2 bottom screws (i already have the correct screwdriver)how do we take apart the T68 cover.i want to clean the dust that is under my screen is that possible to do by myself??
Cytech Joined: Feb 19, 2002 Posts: > 500 From: Stockholm, Sweden PM |
hmmm.... ever heard of the search function?
you can use the same guide as the cover changing guide...
http://www.totonox.com/guide.html |
time to update your bookmarks... Totnox has changed the link to the coverguide.... |
it says the page cannot be found,totonox keeps changing his page!!!i cant keep up with the updates
thanks i found it!!!!!!!!!!
