Can i use Bluetooth instead of sync station. |
googler Joined: Oct 17, 2004 Posts: 5 PM |
I have a widcomm bluetooth dongle can i use it to connect to my p800 instead of using cable.
govigov Joined: Jul 30, 2004 Posts: > 500 From: Back home - Cochin PM |
I believe it to be yes, if your p800 has bt.
This message was posted from a K500 |
rrojas260 Joined: Dec 13, 2003 Posts: > 500 From: Valencia, Venezuela PM, WWW
Yes except for online updates of course
yes yes yo . . . |
baseballfanz Joined: Sep 21, 2004 Posts: > 500 PM |
You need to set-up the serial connections.
This message was posted from a P900 |
But how , short description please. |
scotsboyuk Joined: Jun 02, 2003 Posts: > 500 From: UK PM, WWW
@googler
Install the software that came with your Bluetooth dongle.
Install the PC Suite software that came with your P800.
In the connection manager there will be the option of a Bluetooth connection, make sure that it is ticked.
Using the bluetooth software, search for your P800 (make sure your P800 is set to 'Discoverable') and when found pair it to your laptop.
You should now be able to establish a dial-up connection, a serial connection, etc with your P800.
You might also want to search through Esato as there is a wealth of information regarding this subject.
"I may be drunk my dear woman, but in the morning I will be sober, and you will still be ugly." WSC |
