What phone do you recommend for my requirements? |
red_ryder Joined: Jun 20, 2002 Posts: 5 PM |
I have used a Nokia 8210 for 3 years now, looking for a change. I won't use Bluetooth, GPRS or WAP, although IR would be nice (for syncing to my PDA). The colour screen on the T68 looks good, and I'm intrigued by the joystick. But the slow sms speed that I keep hearing about is making me apprehensive.
If I do decide on the T68, are there any reasons I should get the T68i? After all, the upgrade is so cheap, but the T68i costs a lot more than the T68. But I really dislike the gold casing and the grey one is out of stock. |
Fahed_2000 Joined: Feb 12, 2002 Posts: > 500 From: UK - London PM, WWW
Get a t68 or a samsung T-100
if you upgread a t68m to the r2e software, you'll have faster sms and menus, just a bit slower than nokia is writing sms. also i personally think that the t68m looks much nicer than the t68i.
Good Shit, Bad Shit, It's all Shit |
orang3 Joined: Mar 28, 2002 Posts: > 500 From: Never_never_Land PM, WWW
a t68m would be a good choice...
Sex is like hacking. You get in, you get out, and you hope you didn't leave something behind that can be traced back to you |
Fingers Joined: Jan 29, 2002 Posts: 468 From: New Zealand PM |
It's your choice really but I like Siemens, the text input is better than the T68's. Apart from that the T68 is the one to go for, just decide on which one you like the look of better the M or the i, you can upgrade the m's firmware to that of the i's anyway. Just my thoughts |
kevin81 Joined: Mar 12, 2002 Posts: 390 From: Stockholm, Sweden PM |
You will, without much hassle, quickly be able to adapt to the joystick. And I believe that you will, as all the other Esato user, soon develop a liking for that little thing
The grey one out of stock? Just wait then, or go to another store. You can also buy online: http://www.expansys.com
xilber Joined: Nov 22, 2001 Posts: 27 From: Pearl of the Orient Seas - Phi PM |
Try Handspring Treo. It's a great PDA phone! |
