Start Wars Imperial March |
Waredafah Joined: May 27, 2002 Posts: 20 From: Norway PM |
Does anyone know where I can find a decent version of the Imperial March from Star Wars?  |
Epedemic Joined: Dec 28, 2001 Posts: > 500 From: Denmark, Copenhagen PM |
press the search button
evoke Joined: Mar 05, 2002 Posts: > 500 PM |
I've got it if you want it - just private message me your number and I'll sent it to
Ed
I'm not stupid you know
No seriously I've tried the search button, but I'm not satisfied with the ones I found. |
Well as I say I've got a good version so if you DO want it private mesage me your number and I will send it you out of the goodness of my heart. it's up to you ! No i will not make mailicious phonecalls!! I'm not bothered either way!! Up tp you mate!
Ed
Patience is a virtue - unfortunately it's one that I don't possess!
[ This Message was edited by: edwardm on 2002-06-16 00:12 ] |
kosa Joined: Aug 08, 2002 Posts: 18 From: Warren PM |
lol |
peejay Joined: Feb 13, 2004 Posts: 40 PM |
I've had the imperial march on all the phones i've had for the last 6 years. Normally I composed it myself using the phone composer, because I could not find it anywhere. I did it with a crappy Sagem, although it had a great composer, the best I've seen to date. Then with the T68 composer, and later on it still sounded decent on the P800.
Now on the P900 I have it as an MP3 and it sounds great! And The Force theme is for personal calls. Got both from Kazaa and then edited them with Adobe Audition. |
Vlammetje Joined: Mar 01, 2003 Posts: > 500 From: Den Haag PM, WWW
On 2004-10-05 22:07:04, kosa wrote:
lol
more than 2 years after the last post, you find this thread so you can post.... 'lol'?
