sony ericsson t610 |
lennydiane Joined: Aug 21, 2004 Posts: 10 PM |
hi i have a sony ericsson t610 it has been working ok but last week it locked up on me when i put my husbands sim in it it works ok any ideas many thanks diane |
Elrond Joined: May 14, 2003 Posts: > 500 From: Slovakia PM, WWW
You probably locked your sim card. Please call your operator to unlock it. You need puk code.
BTW. Welcome on Esato.
[ This Message was edited by: Elrond on 2004-08-21 20:15 ] |
bico Joined: May 19, 2003 Posts: > 500 From: Stockholm, Sweden. PM, WWW
@lennydiane: Welcome to Esato!
Does any (error) messages show up? If so, what do they say?
@Elrond: If the phone is SIM-locked, doesn't one need the PUK code and not the PUK2 code? As far as I know the PIN2 and PUK2 codes are for special network services only.
[ This Message was edited as: Elrond changed from puk2 to puk in the text of his previous post. ]
/bico
[ This Message was edited by: bico on 2004-08-21 21:01 ] |
I forgot that. Thanks for correcting me.
boto43 Joined: Nov 23, 2003 Posts: > 500 From: Trnava-Nitra,Pardubice CSSR PM |
Bico,u r right in every country and every operator but not in Sk orange. We have Puk or Puk 2 code .
This message was posted from a T610 |
for got to say that when i put my sim in another phone it works ok |
Str1ker Joined: Aug 16, 2003 Posts: 206 From: Sussex PM |
Is your husband's sim on the same network as your sim?
yes it is on the same net work |
When you say it "locks up", what happens, is there a message, or does it not start up at all?
it just freezes on what ever it is on |
That is very strange, if it works the other way around, can't you have your husbands phone, and then he can have your phone?
Ok, at least that eliminates the SIM-lock theory.
Does the problem occur after you have been using the phone for a while or does it occur immediately after turning it on? If it occurs immediately after turning it on, take it very easy next time and let it load and initialize everything before you touch anything at all.
Think only one good advice now - go to service center with ur phone and sim
ja cejtim se bejt esatem sk podvedenej  |
