T630: how to rotate pictures. |
elsapo Joined: Aug 17, 2002 Posts: 208 From: Italy PM, WWW
Hi, I'm not able to rotate a picture while it has just been taken using the phone camera.
If I save it, the ROTATE option will alwais be unselectable.
Thanks in advance for your hints.
Cheers.
This message was posted from a T630 |
Thats weird, cos i can rotate it whenever i just want to.
zainahmed Joined: Jun 10, 2004 Posts: 121 From: Pakistan PM |
hi
is this happenes in all ur pics and ur camera is on the normal mode i.e all ur effects are off?
thanks |
After a short investigation I can bed some details:
S format can be edited and rotated, L format can be rotated only, while XL one cannot be neither edited nor rotated.
Is it true?
Yeah youre right. (whats the XL mode?)
No, you can rotate them when you take them with all settings of camera and with default ones, you can only not edit them unless you take them with the small size(120x160)
Thats wierd, i can rotate my pics that i take with the cam
Cats have 9 lives, people have 1, mess with wiv me and u'll have none!
Dont hate the player-Hate the game!
Traders's Guild
[ This Message was edited by: Lynx69 on 2004-07-14 19:49 ] |
The XL mode is a 640x480, standing at the picture info. The XL label is smaller, and it's the last format you can choose pressing one while the camera is on.
I don't know whether it's a CCD format or a kind of interpolation algorithm.
Cheers.
Not every pix can be edited on a weird way. Donnow the reason why. Any idea?
