Copying Contacts from T610 to K700 |
Fritz24 Joined: Jul 25, 2003 Posts: > 500 From: Nottingham, England PM |
I'm currently deliberating whether or not to upgrade my trusty T610 to a K700. I've sent my phonebook (both as a whole and as separate contacts) via Bluetooth to my PC in vCard (.vcf) format.
If I get a K700 will I just be able to Bluetooth the contacts from my PC to the new phone? Will the numbers appear correctly and in the correct section (home, mobile etc) on the K700? I ask this because I've seen that people have been having problems with contacts on the K700.
Thanks in advance
joebmc Joined: Jan 03, 2003 Posts: > 500 From: Kent PM |
Yes you can just bluetooth them but i think they dont go in one name (mobile, home, other) they have muti names
I hope not
Does anyone know this for sure?
Just sent all my contect via bluetooth to my old t610 and it looks like it worked, there are know multiple names in the phone book all contects have the right numbers eg. home, work, other.
So i would imaging that the k700 would work the same as the t610 as its it upgrade!
CyberVisitor Joined: Dec 21, 2001 Posts: > 500 PM |
On 2004-07-06 14:05:03, Fritz24 wrote:
I hope not
It's perfectly safe to send them to the K700i. The new phone will have the numbers displayed correctly, just as they did on the T610.
Also - and this is important - when entering the numbers by sending them to the K700i you take no risk of loosing any numbers if you have more than one number for a person/company. If you on the other hand manually insert multiple numbers in the K700i phonebook for one person/company you risk loosing some of the numbers for individual contacts (the later is what is called the bug in the K700i addressbook and is easy to work around by either 1) entering "one" phone number at a time and saving at once before entering a second and third etc. After that, go back and enter the second phone number and save it before entering the third etc. or 2) by doing as you suggest yourself: sending your old T610 phonebook to the K700i.
[ This Message was edited by: CyberVisitor on 2004-07-06 13:23 ] |
Yes, the numbers will be sorted automatically with respective names. It's because the database stores the endings /H /W /O etc. just as it does when storing numbers/names on your SIM-card.
[ This Message was edited by: CyberVisitor on 2004-07-06 18:19 ] |
Thanks for your replies That's one of my worries sorted anyway.
