Forum > Sony Ericsson / Sony > Accessories > Jabra V Sony Ericsson BT Headsets
Author Jabra V Sony Ericsson BT Headsets
Nitro Fan
W960
Posted: 2004-04-03 16:31
I have a Jabra BT 200 BT Headset that I use with my T610 but if the phone is more than 4 to 5 feet, away from the headset, it just crackles and fades so much as to be useless, are the manufacturers BT headsets better in terms of range? Than Jabra and their like? Or do I just have a faulty headset (yes I do realise that’s a difficult question!) but some one may have some idea of realistic BT Head set ranges.
I have owned the ... T68i T610, P800, P900, P910, P990, W950, P1, W960 But SE have now totally lost the plot.
shug
Posted: 2004-04-03 20:24
I get the full 10m both with my T610 and PC. However if I have any object between my phone and the headset it can be cm. I think that Jabra are better than SE headsets and you've got a badun.
If your firmware is earlier than Rc3 then that could be your problem.
[ This Message was edited by: shug on 2004-04-03 19:26 ]
soichiro
Posted: 2004-04-03 21:21
my T610 + HBH 60 = perfect combo!!
@nitro fan, shug's right. get the latest firmware and hopefully it'll solve the crackling problem
Never, under any circumstances, take a sleeping pill and a laxative on the same night.
