t65 covers |
Uncleben Joined: Dec 05, 2001 Posts: 55 From: Manchester UK PM, WWW
could any body tell me how to remove the front cover off the t65. (its getting dusty under there and would like to clean it)
thanks |
suchet Joined: Dec 20, 2001 Posts: 12 From: UK PM, WWW
I've posted a similar question on this site a while back before I brought my cool T65 - the answer I got was that you cant remove the T65 cover (I wanted to know if changeable fascias was an option on this neat little box.) - The best thing I would suggest is try wiping it with a damp cloth and then shoving it near a hoover (But not too close.) - Maybe the dust could be sucked away. |
bbq Joined: Dec 13, 2001 Posts: 16 From: HK PM |
By unscrewing the 2 screws at the back, you can remove the back cover easily. There are several screws fixing the motherboard which should be taken away at ease as well. After that, the whole unit can be disassemblied and you can clean/change whatever you want, if you can find such assessories!! |
