Forum > Sony Ericsson / Sony > Software, Firmware and Drivers > Hardware code is not what you think...
Author Hardware code is not what you think...
mms 4 the m
Posted: 2002-05-10 17:36
The hardware code is nothing more then a batch number. The so called latter version ie 4a is no better then 1a its just a batch number my latest phone is 1b 02W14... what are your thoughts...
GOwin
Posted: 2002-05-12 03:30
to use your post as an example, 02W14 is not the hardware batch number, it is the date when you phone was manufactured.
your phone has a sticker at the back where it will state the hardware revision number. that is usually different between dates of manufacture.
mine is R1B hardware.
