My T610 wont charge |
BOOYAR Joined: Aug 19, 2003 Posts: 310 From: UK PM |
Well the title says it all.
The charger definately works because i've charged another t610 on it.
Help me please
The manual says it can take up to 30 minutes for the phone to register that it is charging when new and when the battery is very flat.
Do either of these two scenarios match your circumstances?
...Unless I'm very much mistaken
[ This Message was edited by: masseur on 2003-10-14 10:22 ] |
No neither and i've tried it overnight
This message was posted from a T610 |
Sounds like a job for SUPER... I mean !
Anyone know the nearest service centre to macclesfield
This will probably be a problem that needs to go to Celestica (the advanced repair centre) as its unlikely a normal service centre can fix this sort of problem.
Call on 08705 237 237 and they will tell you either way
cfrantzol Joined: Oct 14, 2003 Posts: 3 From: Athens, GR PM |
Have u tried to clean the electrical contacts at the bottom of your t610? A sharp but soft toothpick or a match broken into half is perfect for the job. Rub the contacts GENTLY and dry. No alcohol or cleaning solutions. It worked for me.
Also check that yr battery is seating correctly.
Deanlambert Joined: Sep 10, 2003 Posts: 466 From: East Yorkshire PM |
Could it be that the battery is buggered? Have you tried swapping them and seeing if it will charge then? Only an idea
This message was posted from a T300 |
I'll try the matchstick thing.
My GF has the same phone so i know its not the battery. At the moment i'm charging my battery in her phone so i can still use it.
