dw Joined: Mar 13, 2002 Posts: > 500 From: Sweden PM, WWW
Hey all.. one thing I almost consider a bug
is the stall speed in the melody composer.
Atleast it's something they should fix in later software versions imho.
If you edit Funky or any other melody that has some lenght to it
you will understand what I mean.
I can't find a way to jump to the start of the tune one will have to
hold the joystick to the left and wait for longer time then it takes to play the tune before you finally end up at the begining.
This is what I did to edit a tune and put in some effects
I choose the tune and then in options choose to send it
then I sent it to my portable using IR and opened it up
in Notepad I edited the MELODY: line (make sure its one long line if you get linefeeds in it the phone wont be able to open it in its composer)
backon/backoff <- Display/keypad light control
ledon/ledoff <- The green led in topleft
vibeon/vibeoff <- vibration
(theres more but I dont know them yet)
I noticed you have to be careful to where you put the control
instructions in the tune or it will halt where theres an error.
When you done just make sure its stores name.imy then put the
phone to recive mode and transfer it back.
Do anyone know of a iMelody composer that can handle
control codes and you can check if its valid/working before
transfering it to the phone?
(Perhaps I should add that I use a T68i)
[ This Message was edited by: dw on 2002-04-10 09:08 ] |
