Forum > Sony Ericsson / Sony > GPRS, WAP, MMS and Email setup > *T68* My GPRS WAP doesn't work, Help! (Canada)
Author *T68* My GPRS WAP doesn't work, Help! (Canada)
Powa
Posted: 2001-12-25 22:39
i'm living in Canada, i just got my t68 a few days ago. i have already typed in all the settings that require to go on the wap, but it saids "communication error. Try again or check your settings." message. My friends (2 of them) uses the exact same settings and they are able to go on the wap, but everytime after "connect" and "loading", this message pops up. My current network is Rogers AT&T, if anyone knows what's wrong with my phone, please give me a solution, thanks.
xenious
P900
Posted: 2001-12-26 00:28
That happens to me sometimes. Basically it is a wap browser timeout message. Usually if I move to a better signal strength and try again it will work.
-jim
Powa
Posted: 2001-12-27 18:56
I've made a phone call to my operator again, they said they don't support T39 and T68 yet, so they can't do anything about it, damn... is there any phone's network setting is the same as these 2 phones? (my operator only support motorola's phone...)
matt5115
Posted: 2001-12-27 19:23
Just because the operator does not support the phone, does not mean it won't work. I live in Florida, USA and switched from Voicestream to AT&T. Neither supports the phone, but if you kow the settings, then GPRS will work.
If anyone wants the AT&T settings I use on my T68 GPRS, let me know.
Matthew
jh67
S700
Posted: 2001-12-27 19:26
POWA : I'm not in the US or Canada,..but I guess Vodaphone would have the settings for T-39/T-68.
Have you tried to go on WAP using gsm only ?
If this works, your settings for wap are basically ok then.
If not, there could be something in the datacomm-settings. Or the wap-setting itself.
I dont know about Canada, but here in DK, we need a special account for GPRS-use.
Have you tried out other wap-sites ?
Jan
Harleydog
P900
Posted: 2001-12-27 20:16
Matt,
How do you compare ATT to VS? IS ATT better? Also, how long ago did ATT switch to GSM in Florida
thanks
PapaDocta
P900
Posted: 2001-12-27 21:36
Powa,
i used to have the same thing with VS.. what i did is a Master Rest and then created the GPRS again and make sure you change the defualt web page in the wap profile... hope that helps...
Powa
Posted: 2001-12-28 03:46
thx for all the helps, i've finally able to get on the wap. I phoned Rogers AT&T for a total of 4 times, they all said that they don't support and stuff like that, then i try to go on the "chinese costumer service", that guy got my wap online. So in the future anyone got the same problem, just made a contact with them and ask for their manager, THEN they will begin to work on it~~ ^.^
howardh
Posted: 2002-05-22 02:42
Hey can you tell me how you get WAP from AT&T/Rogers and whether you have to pay more to get WAP?
TIA!
genie388
Posted: 2002-06-03 21:49
Hi,
Do you mind post the setting you got on your cell for us to try out, both me and my friend are having problem setup the web on our T68i and we couldn't find any info about the setting.
Thanks very much.
dondori
X1 Black
Posted: 2002-06-03 21:51
POWA: where abouts are u ....... in toronto???
dondori
X1 Black
Posted: 2002-06-03 21:52
if u live in toronto u can go to a location on Kennedy Rd and Steeles, a place called PACIFIC MALL.... they will help u there....
genie388
Posted: 2002-06-06 23:31
Thanks! I live in richmond hill so I think I will go there to have it done. but which shop specific should I try out? I know there are quite a lot of phone store there.
Thanks again!
