belkin t610 problems |
MadBassist Joined: Aug 05, 2003 Posts: 6 From: Kent, UK PM, WWW
ok guys, i know peopel have been having problmes with the belkin bluetooth adapter but not as bad as mine. MPM won't discover my phone nor will my bluetooth neighbourhood, also, my phone can't find my Pc :\. and before you ask yes it is plugged in and the belkin software is installed. I'm isung windows xp pro and the F8T001 bluetooth adapter. many thanks in advance
[ This Message was edited by: MadBassist on 2003-08-06 17:19 ] |
wrath000 Joined: May 14, 2003 Posts: > 500 From: Norway PM |
Did you remember to swich T610 into visible mode?
Connectivity->BlueTooth->Options->Visibility
yeah turned bluetooth on and also selected show phone in the Connectivity > Bluetooth > Options > Visiblity > Show phone
grrr it just wotn work  |
If you put the PC in the discoverable mode (default), can you detect it by searching for it from your phone? (bluetooth->my devices->new device)
yup tried that too and my t610 says 'no devices found. i've tried plugging it into diff usb ports and directly into my pc rather than thru a hub, grrr  |
It looks like Belkin F8T001 is a class 1 bluetooth adaptor (100m range)
The T610 is a class 2 (10m)
I am not sure the two are compatible, I'll try to check it out
[EDIT]
It seems that class 1 and 2 BlueTooth devices are compatible, but you will be limited to 10m range.
Perhaps your dongle is faulty. Do you get any error messages when you try to search for BlueTooth devices on the PC? Check the application log (right-click My Computer->Manage->Event Viewer->Application)
If I had all the answers, I wouldn't have any questions.
[ This Message was edited by: wrath000 on 2003-08-06 18:13 ] |
ok problem solved i think, the cable that coems with the usb dongle doenst seem to help so i jsut plugged it into the back of my pc without the cable n tada, worked fine! |
vaudrj Joined: Sep 05, 2003 Posts: 2 PM |
Hi
I too have the T610 and Belkin adaptor but find the range dissapointing. The phone needs to be within a 1/2 meter of the belkin adaptor in some cases about 10cm any further and the signal is too weak.
Did removing the extension cable help ? |
