Forum > Sony Ericsson / Sony > Accessories > ICT-13 Type Case for the T610??????
Author ICT-13 Type Case for the T610??????
MarcsOnFire
W880 Silver
Posted: 2003-07-16 19:36
Does anyone know if there's one available or whether one will be coming along soon??
I felt the plastic casing gave my T68i good protection from the odd knock if I dropped it.
Thanks in advance
Marc
masseur
Posted: 2003-07-16 19:40
did you try to see if the T610 fits and is secure in that one? I haven't seen one mentioned for the T610.
MarcsOnFire
W880 Silver
Posted: 2003-07-16 19:45
The ICT-13 for the T68i is tapered so the T610 won't fit unfortunately.
I hope do bring one out. I felt it enhanced the look of the T68i.
Marc
sunjivas
Apple iPhone 4S
Posted: 2003-07-16 19:55
yep i wud like one of these aswell. had the ICT-13 for my T68 and it definitely protected such a delicate fone. realised this mornin that the silver paint has chipped off the corner of my T610
Trevsweb
Posted: 2003-07-16 20:12
i saw two types of case that fits the t610 at mobilefun.co.uk im buying one when there in stock
waddie
P900
Posted: 2003-07-17 05:47
there is the ILO-20 and it's sold in SE UK website only. but i don't like the colors, there's pink, green and blue (it's too mushy). it can be worn around the neck.
they're like ICT-13 (plastic holsters). it would have been great if the color is like black, grey or silver.
