How do I send the themes to my T610? Need help :)) |
Xophile Joined: May 31, 2003 Posts: 7 PM |
Hi,
I have a USB cable but I can't figure out how to send the themes to my T610. I can send pics etc but how do I send the themes?
Thanks! |
radical Joined: May 21, 2003 Posts: 22 PM |
Use the send file application from
christersson.org |
Thank you SO much for your reply! I really appreciate it! |
spike731 Joined: Jul 18, 2002 Posts: 124 PM |
Can you tell me what cable you use for your t610, you said it was usb but whats the cable called?, and how much is it?.
This message was posted from a T68i |
I'm using the original SE USB cable called "USB Cable DCU-11"
It's the same cable you use for the T300 and the T68
I bought it for about 300 SEK which today is about 28 EUR |
