Master Reset |
al1307 Joined: Mar 14, 2002 Posts: 181 From: Cambridgeshire, England PM |
Is there anyway to do a master reset without using the touchscreen? I can get into the Master Reset option but as I can't use my touch screen can anyone help?
Thanks
Daniel Christian Joined: Mar 20, 2003 Posts: 25 PM |
I know a solution to format drive C, try this:
http://my-symbian.com/forum/viewtopic.php?t=3412&highlight=master+reset |
If I could use the touch screen that post would be some good to me, but as I cant use the touch screen thanks anyway!
Hey.....you don't need the screen. Just the jog dial. Try it.... |
