Sending SMS |
Hoonior Joined: Jan 22, 2003 Posts: 19 From: Blighty PM |
Have had the phone for a few days now and haven't really had time to play with it to find out all the ins and outs. However, trying to send an SMS is proving a problem. I've sent the numbers on my old phone to this via infrared and saved them. However, when I try to send an SMS, the only viable people it claims to be able to send to are those contacts it has picked up from synching with Outlook.
Any ideas? |
Check that the numbers you IR'd are stored in the mobile number field of the contact.
...Unless I'm very much mistaken
[ This Message was edited by: masseur on 2003-03-26 09:41 ] |
Genius! Thanks. Many a happy hour cutting and pasting coming up! |
lexus Joined: Jan 24, 2002 Posts: 308 From: Montenegro PM, WWW
You don`t have to cut&paste, just tap the errow in front of the number and then choose Mobile(w)(h) |
Even better, so I do!! Any idea why, though, all the contacts names have been copied into Outlook but the numbers haven't? |
