Forum > Sony Ericsson / Sony > Technical > Can't Sync PhoneBook with T300
Author Can't Sync PhoneBook with T300
MeanPony
Posted: 2003-03-24 21:28
I can't seem to sync my phonebook with my laptop I have a T300 and a Laptop running XP Pro. My Laptop recognizes the phone and I can send pictures and ringtones back and forth between the two but I can't send my phonebook.
I was able to send the whole phonebook to the laptop via a vcf file but really would like an easy way to update the contacts on my phone.
Am I missing something.
Thanks
David
krazykritter
Posted: 2003-03-25 08:19
Nope not missing anything, the software doesn't exist to sync the T300 yet. The best you could do it send your phone book to your laptop, edit it in notepad or something and send it back.
Matthew Stevens
Nokia 3650
Jabra BT200, BluePen BT Dongle
T-Mobile USA
Prulleman
T68i
Posted: 2003-03-25 17:52
Have you tried XTNDconnect
That should do it...
at least with a t68i and why not a t300??
[ This Message was edited by: Prulleman on 2003-03-25 16:53 ]
krazykritter
Posted: 2003-03-25 18:10
It doesn't work becasue the T300 doesn't support the SyncML standard by which most of the sync programs use to sync with. But before I knew that I did try it and it doesn't work.
Matthew Stevens
Nokia 3650
T-Mobile USA
