Sony Xperia Rumours 2018 |
XZ2c is shorter than iphone 8.
3mm.
Thinner is impossible, iphone 8 has 1821mAh.
Lonewolf223 Joined: Dec 24, 2017 Posts: 361 PM |
Xz2 compact dimensions and weight
135 x 65 x 12.1 mm
168g
2870 mah
Iphone 8 dimensions and weight
138.4 x 67.3 x 7.3 mm
148g
1821 mah
S9 dimensions and weight
147.7 x 68.7 x 8.5 mm
163g
3000mah
The difference is clear
S9 is not in the xz2 compact category
I like the xz2 compact more than the xz2 except for the looks |
The compact has smaller battery, smaller screen, few of them smaller front camera, usually single sim.
All this makes it cheaper than the sibling.
I dont understant why the outside is always cheaper too.
No compact has ever looked as premium as the 5.2" version.
When you hold Z3 then Z3c , they feel very different. |
badassmam Joined: Nov 07, 2007 Posts: > 500 PM |
The iPhone 8 is thin which makes it easy to handle, the Compact is very thick so it seems a lot less premium than it's specs suggest. I'll admit that the iPhone 8 was the wrong comparison because of the screen size but despite the bezels it feels great.
The S9 is a different case, you get much more screen so it feels very comparable to the Compact and a lot smaller than the XZ2. The S9+ is big but when you turn the screen on it dominates everything and feels very immersive.
I guess it's my personal gripe because I don't want the Compact to be bigger than the XZ1 Compact , I just wanted the bigger screen in the same body. If you keep increasing the size and have to eventually use two hands then it's not compact anymore. They could've at least kept the headphone jack given the size of the modafoka.
[ This Message was edited by: badassmam on 2018-05-20 16:36 ] |
I like what they did to XA2.
From 5" to 5.2" and also shoter body.
Compact with 4.8" and same 13,1cm would be great.
Same way XZ2 with 5.5 " and 14,8 or 15 cm.
Keeping 16:9 screen. |
I forgot to mention that the XZ2 battery is excellent for the flagship category, I feel it could definitely give you a full day. Also, Samsung makes their own version of every basic app that you can't disable so you get the Samsung calendar app next to the Google app and that doubles the number of apps in the drawer. It's annoying to see that much extra clutter.
One issue with the XZ2 is that it's slippery like nothing I've seen before. You cannot leave it face up on a flat surface because it'll move for sure. Most likely aerodynamic phone in history. |
Looks like Premium does not slide on surface.
At least as much as I have seen so far.
Hope they bring more colors. But I do like the silver. |
rubik_cat Joined: Mar 01, 2018 Posts: 64 PM |
After watching XZ2/ XZ2C disassembly video, I wonder why Sony put too much brackets. If they remove those plastic brackets, I think XZ2/XZ2C won't heavier than competitor's one. |
PA gave 9 too OP6...
That is why I say brand matters.
Phone lacks a lot of stuff. |
Luca-S Joined: Sep 11, 2012 Posts: 278 PM |
Phone Arena is a joke.
I have it in my adblock list.
Are you nervous? |
Yes PhoneArena is a joke. But, actually, I think they gave OP6 a 9 because of how good the specs and features are with that affordable price.
Oh, check out NotebookCheck and AndroidPit websites for XZ2 reviews. They're honest and sums up my experiences so far. Except, the camera is excellent and the phone doesn't feel thick at all.
I also got my XZ2 and yes, it really is amazing. Its camera is actually good, has amazing battery life (I've had a hard time wasting this phone's battery), it also has impressive speed and performance, it has an arguably great looking design, especially in green, I got used to the fps in hours (with a case), it isn't the thinnest feeling phone I've ever held but it doesn't feel thick at all and I got used to the heavy weight quickly, the display is superb, nothing more to say.
The only downsides:
- The lack of 3.5 mm headphone jack bugs me.
- It is very slippery.
- The speaker is louder, but I don't see any difference to my old Z3 in quality, and it seems like the quality over earphones is a bit worse(?)
- Camera app crashes sometimes.
- It is hard to find a good tempered glass screen protector for this phone.
The battery:
Daily Drivers: Galaxy S23 Ultra, Galaxy S22 Ultra, and iPhone 14 Pro Max Secondary: vivo X80 Pro Still using as a backup: Xperia XZ2 Still using (not as much): Galaxy Tab A 8.0 |
Of course that for $520 the OP5 is better than midranges.
Point is if you remove things from G7, S9 and XZ2 that OP6 does not have these phones would be cheaper as well.
Ricky D Joined: Feb 05, 2007 Posts: > 500 From: UK (living in Beijing) PM, WWW
What's missing from OP6 to warrant the extra £300-400?
..except the middle of the notification bar.
[ This Message was edited by: Ricky D on 2018-05-21 12:39 ] I have a dig bick You read that wrong |
IP68
Stereo Speakers
HDR screen
4K HDR
Slot micro sd
2nd cam is useless type ( no super wide, no telephoto nor monocrhome)
2nd does not have even EIS
It has notch
Some ppl like the " wireless " charging. I dont care, so I usually dont mention it.
Looks like it does not have treble.
DACHA Joined: May 17, 2011 Posts: > 500 PM |
It is missing the features you listed but I am sure that the OP6 will take better photos than the XZ2.
No stereo speaker but it has 3.5mm audio jack.
SD cards are slow, go to XDA forum and read about the 18mb/s read write speed on the XZ2.
OP6 has IOS XZ2 does not.
Every product has its weaknesses but for $300 less than the XZ2 the OP6 is an excellent phone.
Edit: Oh and forgot one very important part, OP6 supports VoLTE on T-Mobile and AT&T in the USA. That is the reason why I didn't buy the XZ2 but will give the OP6 a shot.
[ This Message was edited by: DACHA on 2018-05-21 16:38 ] |
