Sony Xperia Rumours 2018 |
XperiaJunkie Joined: Dec 13, 2012 Posts: > 500 From: Parts Unknown PM, WWW
If it ment Sony can utilise the space taken up by the headphone jack and use for a larger battery or bigger speakers then I'm up for that but not for the sake of saving a bit cash by leaving it out.
I'm so happy 'cause today I've found my friends ... They're in my head
badassmam Joined: Nov 07, 2007 Posts: > 500 PM |
No disrespect to the photoshop skills but the design is ugly. They do not look as well executed as the S7 Edge so its already outdated. They should add some side bezel and trim the top and bottom, it may not affect the bezel ratio but it would look a lot better as you create the illusion that its even more bezel free like the G6 when the percentage says otherwise. The curves need to be subtle. I have a feeling they will look like the XA2....nice but not worth the hype.
If I'm travelling I need wired headphones for the battery, I do a lot of conferences so I can't rely on wireless. I sure hope they bundle some good headphones but that never happens in the UK. |
hgautam Joined: Jan 29, 2006 Posts: > 500 PM |
Most of you get too excited too quickly.
The dimensions are for the whole phone... The width of the phone and the display even if it is bezeless live XA2 cannot be almost equal or 1mm something. Even the XA2 has around 2mm screen and body gap on both left and right sides, so around 4mm difference between screen and phone width. So this phone seems to have an 18:9 display only... So it turns out that this phone has 76% stb ratio and not 81% which is still great for me if there are stereo speakers and slight curved top and bottom...
@ascariss can you please make another photo with 18:9 aspect ratio and top and bottom curved to be very subtle like viewing XA2 from the top or bottom... |
blackzeros Joined: Jul 21, 2015 Posts: 381 PM |
but uaproof show 4k 16:9 screen |
I have always used the jack.
I dont like the earphones that come with smartphones, so I buy the one I want.
The main problems are :
1) Price : usb c earphones will cost more, many ppl still like simple earphones because they dont understand about sound quality. So they end up with cheap options. And you can use from any brand.
2) software : what if the audio settings (DSEE HX, Clear Audio) dont work with earphones of other brand anymore? Something like this happens to HTC u11.
3) availability: Sony does not sell all accessories worldwide, in many markets the flagships dont come with fast charger. XZ here did not have even earphones in the box. What if I need a new usb c earphones? Also that dock to charge phones dont show up here since z3. There is another type of dock for Z3+ and following phones..
4) Since Z3, the usb can be used for audio. But jack was kept. Didnt they say last year there was no plan to remove jack?
5) like our friend BADASSMAM says, bluetooth earphone/headphones dont last much longer, ppl have to recharge often. Also with bluetooth on the battery drain increases.
6) The strongest of the 3 levels of STAMINA works like it used to be on android J, K and L. It turns off things when screen is off. What if NFC/bluetooth goes off too? How can you use?
I remember that few models of Sony Ericson feature phones used same port for audio/electricity.
It was really bad. I remember my earphones died and price of new ones was about 1/8 of what the cellphone costed.
Removing the audio jack is the worst thing ever... It's not that big that it would be a problem to continue using in a phone and when current phones easily fit a jack even bezeless ones than there is just no justification to remove it... For most purposes we all have moved to Bluetooth like in the car or home audios but headphones are a different story altogether... Regular charging and battery life degradation with time are the reasons I have stayed away from Bluetooth headphones or a phone without a jack... Don't know why it would be a burden to keep including one in future models... I would be very sad if my next xperia doesn't have the jack... Will have to compromise by carrying an adapter all the time... |
Archdragoon Joined: Mar 18, 2015 Posts: > 500 PM |
So... is this for real ?
BTW I'm happy if SONY going to remove the headphone jack from Xperia which might mean they're going to stop using qualcomm DAC
Device : Xperia 1 II Headphone : MDR-M1ST + MUC-S12SB1, ATH-DSR9BT, WH-1000XM4 DAC/AMP : PHA-2A |
astider Joined: Jan 21, 2018 Posts: 61 PM |
Just my wild imagination, what if the new Xperia is the first smartphone to feature 4.4mm balanced audio jack? |
Stop that imagination. It wouldn't be good to have 4.4mm on phone. I own PHA-2A and I can say that it use a lot of power and does heat up when using 4.4mm for a while.
I tried Walkman with 4.4mm jack and the sound was great. but you're right, it draw more power than 3.5mm ...and that's not good lol
Lonewolf223 Joined: Dec 24, 2017 Posts: 361 PM |
Removing 3.5mm jack and finding space for battery?
Thats total bullshit move
I hope sony dont go on a suicide mission |
maiaramdan Joined: Dec 13, 2012 Posts: 308 From: Kazan living in Sumy PM |
If anyone see the patent photo closely
You will see that there's a junction from the wire outed from the usb-c it will have 3.5 for any headphone in one end and the other end another usb-c for charging
So it will be like 2 in 1 combo |
X350 Joined: Jun 22, 2017 Posts: 47 PM |
Agree with you |
I forgive the removal of jack if they make a phone able to to this..
http://www.slashleaks.com/wp-content/uploads/ar.png
[ This Message was edited by: Moe87 on 2018-01-21 16:35 ] |
Source insider: 2018 purchase standards: Xiaolong 845, LCD screen, waterproof, open source, single camera, memory card, no ads. |
