Can External Disk Space of Xperia S be Replaced / Upgraded? |
mode Joined: Jan 12, 2007 Posts: > 500 PM |
As shown in this link http://www.xperiablog.net/201[....]changed-if-you-really-need-to/ we now know that replacing the battery on Xperia S can be done domestically eventhough it has a unibody form factor. But now that I have 64gb of removable external disk space in my Arc S, I don't think I can downgrade back to 32gb as it wasn't enough before and it'll never be enough for me. So as the title suggests, does anyone know if the Xperia S' external (unremovable) card can be replaced/upgraded?
Ericsson EH97, GA628, GF768, A2618s, T29s Sony Ericsson T68i, S700i, P990i, Z558i, W902, W995, X10, Arc S *Xperia V*White*Black MW600*Sandisk Mobile Ultra 64GB microSDXC* | |
adsada Joined: Aug 23, 2008 Posts: > 500 From: Scotland PM |
I'm guessing you mean internal memory?
I'm guessing this is impossible, unlike the battery the memory chip will most likely be an attached piece of the motherboard, so unless you're expert and fixing phones and know you way around soldering
Arne Anka Joined: Nov 05, 2003 Posts: > 500 From: Sweden PM |
Unless you know how to use a soldering iron I wouldn't recommend it. This is how a typical eMMC (as in embedded MMC) looks like.
[ This Message was edited by: Arne Anka on 2012-03-23 11:09 ] |
vlotnet Joined: May 11, 2008 Posts: 88 PM |
MicroSD and removable batteries for the win.
Nope, it isn't internal memory, more like external memory just like what most Samsung Androids have, then there's the external SD. Internal memory is something else AFAIK. Anyway, if that's what eMMC looks like and soldering is absolutely required then I guess I'll pass the Xperia S for now. But I do believe what's making it perform flawlessly is due to the fact that it has a large memory and not dependent on microSD cards like the previous Xperias
I would use the example of a computer, you have the internal hard drive that sits inside the computer, and an external hard drive would be one that you plug into your computer through usb. So surely the xperia s has internal memory only?
out of interest what do you have that uses 64gb? is it just your music?
laffen Joined: Aug 07, 2001 Posts: > 500 From: Oslo, Norway PM |
This is just a matter of definitions. The 32 GB eMMC is called Flash memory in the Xperia S whitepaper. It is internal storage in the same way SSD disk are on a PC. Nobody calls SSD storage for internal memory, do they? | |
