How to customize my Samsung Galaxy Y S5360? |
mobile_fish Joined: Sep 24, 2005 Posts: 61 PM |
Was: purchased new phone
I just have purchase my new phone .. samsung galaxy y s5360
How do I customize my phone to get better user experience ?
I have installed HandCent SMS ... Dolphin HD browser etc. Do I need to upgrade any softwares / tools for better functioning ?
Open to your suggestions.
Thanks
[ This Message was edited by: tranced on 2012-02-15 12:46 ] |
Hi!
If you want to get a better experience, then you should download themes that suit your taste. Also, you can download apps recommended by the Android Market. They're sometimes good.
Your software comes with a recent version. Not the latest Android version though. You could check if there's an update for it anyway.
What are the recommended apps ?
And
How do you check for updates ? |
The recommended apps are featured in the Android Market main page. And for checking updates, just go to settings and then about phones. There you will look for the Check update option.
