Battery In T68 |
Buzz Joined: Jan 02, 2002 Posts: 87 From: UK PM |
found this looking round the web, does anyone know if this is the same battery as in the t68???
http://www.panasonic.com/industrial/battery/oem/images/pdf/li-poly.pdf
check out the cycles:( |
ewap8 Joined: Nov 30, 2001 Posts: 398 From: Dubai PM |
how the hell can u use such a battery with a T68?????
yesuwa Joined: Feb 01, 2002 Posts: 5 PM |
yes?i have disassembled one t28's battery,i found it was made by SONY energy Inc.
so i guess t68 also uses a sony one |
nwmq1 Joined: Dec 28, 2001 Posts: 277 From: Sweden PM |
I'm now sure if I understand your question correctly, if you're asking if the T68 has a lithium-polymer then: Yes, it does.
That article was pretty old, from 1999... |
