Can the vibration be turned off on the Red Carpet theme for C902 |
wifiwupding Joined: Sep 07, 2009 Posts: 54 PM |
Hi all as the title says can it be turned off, i cant find anything in the phone that indicates you can |
In the menu: options-main menu layout.
Change it to another and you won't have it anymore. The icons will change though. Btw thats what flash theme does
thanks |
Another way is to go to settings,sounds and alerts. Then scroll down to vibrate and turn it off. You don't get the vibrate when you move through the icons on the main menu but you also lose the vibrate function when the phone rings.
