T_T help! |
redflicker Joined: Aug 28, 2009 Posts: 3 PM |
can u giv me another settings for my opera mod 2.00
coz my older settings not already..processing..
wat should i put on this-->
the adress to connect:
server:
port*:
opera mini server:
thnx..a lot! |
ChrizChild Joined: Apr 14, 2009 Posts: 123 From: Inner Corner PM |
Redflicker my thread k ule,hehehe
Redflicker e2 settings ng 2.00 ndi q lng mlala kc kccra lang khapon ng memory crd q, kya ubos ung file q..
Shadow Conek:Check
Adres 2 Conek: http://wap.portal.globe.com.ph
or any fresite na gs2 mu.
Server and Port: Blank mu nlang
OM Server: Mark mu ung 80.232.117.10:80
or kung gs2 mu gwa k nlang ule.
Mark mu naman ung Other tpos type mu 2 server.operamini.com:80
Edit q 2 [WALA] nga pla xng Reset OM Server at an Eror
kc pag nag Eror k bbalik ka sa Server na 80.232.117.10:80
Try muna
[ This Message was edited by: ChrizChild on 2009-08-29 03:35 ] |
bt gnun d sya ng proprocess..T_T |
red pag ayaw mag process ng 2.00 mu UNCHECK mu ung Shadow Conek..
my problema ata sa adress to conect ska opera mini server..aus n kc ngproprocess n kya lng..
sa settings tlga my prob |
bkt anu nman ung prob nya? db sbi mu nkaconek kna rin dati jan?
my iba k p bang adress to connect n pwede kong ilgy? |
ang addres 2 conek ay mga fresite ng globe un.
wapx.amob.com
ea.amob.com
wapshop.gameloft.com
wap.b.abs-cbn.com
ea.amob.com
mrmami pa sa thread ni Bos Aqua
[ This Message was edited by: ChrizChild on 2009-08-29 06:12 ] |
