Forum > Sony Ericsson / Sony > Symbian phones > low bluetooth audio volume
Author low bluetooth audio volume
jstrike
Posted: 2009-07-07 11:24
I'm looking at a solution for the low volume on bluetooth headsets. At the moment i have a p1i and it great volume on a wired headset. However when i connect a bluetooth headset, the volume is always lacking, most often i need to put the volume at max and then it's still not enough.
Now what i know to be true. The headset is capable of producing louder sounds. I have a headset which has a built in radio and allows for normal mp3 to be connected to it (yes, it sounds silly, but it does allow analog (wired) connections) anyway these volumes + the volume of the phone conversations are significantly louder the the mp3 playback from my p1i via a2dp.
I have tried the swmail volume mod. Seems to work on wired headsets but the bt audio still seems to be on the low side.
Is there any solution to this problem? The weird thing is... the phone conversations are a lot louder. I just can't understand why there is this difference (yes i have looked at the volume panel of the p1i)
[ This Message was edited by: jstrike on 2009-07-07 10:25 ]
jstrike
Posted: 2009-07-17 10:06
noone?
