globe gprs problem pls pls pls HeLp!!!! (ph only) |
prAnkie Joined: Apr 03, 2002 Posts: 102 From: san juan ghils PM |
hi guys. maybe u can help me. ksi mga last 4 days nakuha ko un 6100 ko, den 2mawg ako sa glbe 4 gprs activation, sabi mga 24 hrs daw activated na. d nxt day, 2mwg ako and sabi nila meron daw silang problema or smthing. til now la parin. btw, prepaid ako. and bkt dati nun naka t68i ako, nakakawap nman ako. tinype ko na rin un thing na GO N6100 FOR SETTINGS??? SO bat Ganun Ang Globe? sa smart prepaid, ok ba gprs?
pls people i need 2 have GRPS help!!!!!!
Jowi Joined: Feb 21, 2002 Posts: > 500 From: Pilipinas PM, WWW
input the settings manually on your phone...don't rely on that "GO" thing...it will just mess up your settings....as you says, YOU CAN ACCESS when you have a t68...so there's something wrong w/ your 6610's settings.
[ This Message was edited by: Jowi on 2003-01-20 16:18 ] |
mari Joined: Jul 02, 2002 Posts: 71 From: Makati, Philippines PM |
@prankie- my bro (prepaid too) had to wait for 4 days b4 he got his gprs signal. Not to mention the fact that globe's gprs has been going bonkers since last wk. Patience is a virtue. :-D or u can also try calling nokiacare and ask their cs to run u thru their settings. My boss had a simělar prob knina and i had to call nokiacare, they were helpful naman.
This message was posted from a T68i |
GOwin Joined: Jan 17, 2002 Posts: > 500 From: .uʍop ǝpısdn s& PM, WWW
continue here: Globe Telcom Settings and Configuration thread |
Lowrider Joined: Jan 20, 2003 Posts: 5 PM |
It's probably ur wap settings.That happened to me too when i bought a new globe sim pack,i had 2 call globe hotline 2 request for gprs activation.I kept on waiting and waiting but nada! So,i had 2 coax my brother to swap sims,since his prepaid sim can access wap via gprs.
This message was posted from a Nokia |
