Forum > Sony Ericsson / Sony > General > I need help with a couple of C902 question
Author I need help with a couple of C902 question
Edwarrior
Posted: 2009-05-11 10:08
I recently just brought a c902 and i am unsure of some features, could anyone please answer some questions?
- What is the total sms/text message storage capacity?
- With the k750i and w810i, it is possible to turn on the light permanently to use as a torch light. Is it possible to do this with the c902?
- Is it possible to use the front camera as an actual camera as opposed to only being usable for video calling?
- Are there any tips and tricks with the c902?
- Also, my slide out camera area that is shown at the front when it is slid out, is made of a roughish plastic material (not smooth like some images i saw on google). Is this how it is meant to be?
Thanks alot
[ This Message was edited by: edwarrior on 2009-05-11 09:43 ]
[ This Message was edited by: laffen on 2009-05-11 10:21 ]
chombos1
Posted: 2009-05-11 11:17
Thanks alot
- had got 1200 messages on mine (and i don't know the max number)
- yes you can use the various modified MENU.ML files to add torch function in the organizer
- yes you can record short 40 sec videos from the front cam. (do a simple search)
- you can use numerous modified camdrivers on the net (including mine)
- mmmm.... don't know anything about it!! sorry.
Muhammad-Oli
Sony Xperia Z
Posted: 2009-05-11 11:39
In regard to the final question, yes it is supposed to be like that. You should be glad because you have a later model C902. That rough plastic is supposed to stop the camera slider from scratching the phone. Earlier models had glossy plastic which scratched very easy. I should know, mine is pretty scratched.
glorfingal
Posted: 2009-05-12 11:56
if you use the leds as a torch you will damage them. leds DO NOT like
to get too hot .... we have the same problem with mountain bike led
lights !
Edwarrior
Posted: 2009-05-12 12:23
Hey, thanks guys, ive been looking on the internet for a way to use the front camera to record a video, but i cant seem to find one.
A link please or little guide please?
Also, does the c902 have a light sensor?
Thanks =]
[ This Message was edited by: Edwarrior on 2009-05-12 11:28 ]
