C510 stuck pixel |
JJ! Joined: Sep 13, 2005 Posts: > 500 PM |
I received my shiny new C510 from CPW today and there is one rather annoying bright white pixel!
As it was bought via the website I can easily return it.... I know its only 1 pixel so its deciding whether to live with it or not!!!
Anyone else got any stuck pixels on there C510?
JJ! (formerly justy197  (+6, -0) |
No i have not had any pixel problems but yes i should return it though it depends if it bothers you or not. I would return it a it would distract me. I have not had any major problems with this phone |
its only 1, but as I have seen it, its all i can see now! Will get it exchanged as apart from that, the phone is excellent!
golemsmate Joined: Nov 09, 2007 Posts: 442 From: United Kingdom PM |
depends, if its just on the corner MAYBE i could put up with it but does the dead pixel indicate other problems? |
GavGlasgow Joined: Mar 24, 2009 Posts: 13 PM |
Doing the maths 320x240 = 76800 pixels
Are you sure its only one pixel and not a group of pixels?
is it that easy to see a 0.1mm square?
[ This Message was edited by: GavGlasgow on 2009-04-23 00:29 ] |
yesno Joined: Apr 12, 2009 Posts: 33 PM |
hey all the smart people over here
hey guys something happened to my C510
ive just used it for a week
and now its showing no network coverage no battery colour like green red
even though its charged and shows 82 %
also i cant tranfer files from bletooth
CAN ANYONE HELP ME OVER HERE |
moreover i thought of using a master reset and now evrything is gone
even all the themes except the rubbish clarity
This phone is new and has lots of bugs
plz help me |
ok now my cell is working 100% normal thanks to SEUS update
i noticed that older formware R1DA029 had lots of bugs
But now mine is R1DA032
lets see if this firmware has bugs |
senthil Joined: Mar 06, 2008 Posts: 3 PM |
a line of pixels were stuck for me when i used multiple applications(nearly 3 or more... hehe ), overloading the RAM and when i close some, it got corrected
strauts Joined: Feb 22, 2008 Posts: 180 From: latvia Dunalka PM |
in varianty is said that tou can do the varianty fixing if there is not working 4 or mor pixels
STRAUTS |
VLADISLAUS Joined: May 26, 2010 Posts: 176 From: Jogjakarta, ID PM |
my C510 has a -like- green line in the left LCD
can be seen if my phone starting up or @black screen
anybody have some problem?
"i guess destiny is not the path given to us.. but the path we choose for ourselves.." -megamind- |
