Flash themes does not work. |
Zdarlight Joined: Mar 23, 2009 Posts: 54 PM |
I'm installing flash themes, using A2 uploader, but all the themes are bugged.. When I try to click on icon in menu , it doesnt work.... Can somebody help me? |
for what phone?
w595. IDK why my avatar doesnt show it |
lukechris Joined: Dec 30, 2007 Posts: > 500 From: Preston, UK PM, WWW
I have w595 put them into the pictures folder on your memory card
so I dont need to flash them with A2 uploader ?? |
JeNeI Joined: Nov 25, 2006 Posts: 24 From: Romania PM |
You have to install 2.1 flash themes for w595.You probably installed 2.0 or 1.1 flash themes.Look after themes for w595. |
rdnymllnsktr Joined: Feb 04, 2004 Posts: > 500 From: California, but now in Plano, PM, WWW
In addition, if you put flash themes in one phone that was created for another phone, the menu will act the way you specified that yours is acting. Finally, ignore the other poster, who stated that you should put them in your picture folder. This is incorrect. That's only if you want to view the flash file, not if you want to get it to work as your menu.
MyPhoneExplorer is the new FMA!  http://www.fjsoft.at/en/downloads.php |
wow, thanks for help guys ;D |
