K850i Backlight Problem |
parkenator Joined: Jun 20, 2006 Posts: 6 PM |
Apologies if this has already been posted about, i have had a quick look and cant see anything.
Basically my problem is that when i am texting or using my phone the backlight cuts out, the lights on the keypad stay lit up but the light for the screen goes off. If i hold the phone at the right angle i can see the screen is still on but the backlight is off so i can see nothing on screen. It stays off for about 20 seconds then the keyboard lights go out, as tho the backlight has timed out normally at which time i can push the buttons and the backlight comes back on.
Can anyone suggest a fix, other than takin it to O2 to be repaired. which i may do any way as i am also experiencing problems with the touch buttons too.
[ This Message was edited by: parkenator on 2009-02-20 12:47 ] |
StevenC Joined: Aug 23, 2008 Posts: > 500 From: NY PM |
Seems to be a hardware problem (loose cable, or bad power supply to screen backlight). But I ink the problem is with the screen module only, not the phone itself. Take it to repair. |
I think that will probably be my best idea. Do you know if this is likely to be classed as a chargable repair or will i not really know til someone has looked at the phone
I don't know. |
TimeWriter Joined: Nov 02, 2008 Posts: 103 PM |
But that can be a software problem. Do you have the latest firmware on it?
gtcool Joined: Mar 10, 2009 Posts: 1 PM |
I am having the same problem. I went to a service center and they asked me to change my entire display which would cost me about 1500 Rs.( 1 dollar= 50 Rs approx)... Is there ne other solution to this problem??? |
munkynuts Joined: May 14, 2009 Posts: 1 PM |
This is a screen problem. The membrane attaching the screen to the mother board passes directly underneath the down, 5,6,8 and 9 buttons. I'm guessing that the down button is the one that gets most widely used so I presume over time the pressure knackers the membrane.
I got a replacement screen off ebay and changed it myself. Works a treat. There is a handy video guide on youtube for dismantling it.
http://www.youtube.com/watch?v=XQmJJ_8wNCc |
asmyl Joined: Apr 02, 2008 Posts: 53 PM |
I got the same problem today when I accidentally drop my k850 and hit the edge of my table. I found at the left side of my phone small peeled off near to button number 1. Every time I use number 1 button the light cut off and l have to wait until 20s to get back the light. |
Ikma, that looks like there is someting broken. Try to open it, maybe you can find what is wrong.
Just open it it and found the display cabel crack, and the problem solve. I am careless during open it I have cut a bit the memory/sims cable and now memory card cannot be read, my question is the any replacement available |
Ai maybe on ebay. Or a waterdamaged one, cause you only need the cables? I hope someone can confirm me on that.
