Error after updating K750 firmware |
soloasylum Joined: Feb 03, 2009 Posts: 1 PM |
I just read that R1CA021 is the most stable version of k750 software. My phone was facing random shutdowns so I decided to upgrade to R1CA021 version.
When I installed the Main and Flash using xs++ 2.2 and restarted the phone. It showed progress bar for some time and then following text appeared "Configuration error. Please contact your network operator or service center"
Am I missing something. I think its customization. How can I do this and from where can I download customization files? |
read this tutorial and you'll see what you are missing:
Tutorial: XS++ General Usage (Flashing, Customizing and File System Operations)
crystal_view Joined: Feb 03, 2009 Posts: 2 PM |
dear, i use my mob (SE K750) for movies and i am facing the problem which is sometimes i stop the movie due to some work and i feel soo much booring to hold joystick untill the movie comes to the leaving point in timeline. are you getting my point? i want to know the solution to jump a specific time in media player either via default media player options or alternative media player.
rizwan |
tj rocks Joined: Dec 20, 2008 Posts: 25 PM |
i think u have'nt installed the cust pack
while flashing it's fs and main also install cust pack compatible to it which is already in XS++ 3.1 .. install according to your area |
what is (cust pack and xs++ 3.1) & where i can find it (web path)? actually i am not related with mobile field thats why i am asking about it. |
