C905 Flashig |
teapea Joined: Apr 06, 2004 Posts: 28 PM |
What with the Voda problems and WiFi - I want to de-brand my phone. It looks like all the buttons are in the same place as the original firmware (unlike the K800 red and green call buttons) so should be OK.
Has anyone flashed their C905 yet? Any pros/cons? |
strizlow800 Joined: Aug 23, 2006 Posts: > 500 From: Macedonia, Skopje PM |
You can try using totalgsm to flash your phone. it should be able to debrand it... www.totalgsm.org
yea g Joined: Jul 02, 2008 Posts: > 500 From: New Zealand PM, WWW
nah, totalgsm don't have C905 firmware yet
Check out the Esato New Zealanders thread, we have cookies!!
[ This Message was edited by: yea g on 2008-10-31 09:03 ] |
SilveR. Joined: May 03, 2002 Posts: > 500 PM |
http://davinciteam.eu/index.html has C905 firmwares, remove Vodafone crap asap..
good luck
Sainty Joined: Nov 30, 2004 Posts: 485 From: UK PM |
Select:
C905 R1BA038 CID52 CUSTOMIZED UNITED KINGDOM WESTERN-EUROPE - EN EU CA NL FR GL DE PT ES TR PL
Like I did - very happy with my C905 now
Sainty - Ex Vodafone Sales Advisor
Nokia 402 -> Nokia 3310 -> Nokia 3510i -> Nokia 6100 -> SE V800i -> Samsung D500 -> SE K750i -> SE W900i -> SE K800i -> SE P990i -> SE K850i -> SE W960i -> SE C905i -> SE X10i |
robbie1 Joined: Feb 17, 2004 Posts: 49 PM |
what option do i need to use for davinci if i have a orange branded phone.
want to make sure i get it right and also how long does the process take???
thanks |
reesy Joined: Feb 17, 2004 Posts: 34 From: Derby, UK PM |
@Sainty..
Did your debrand do the following?
Added 'View on Map' to the options of a geotagged foto
Improve lock on the gps, i.e. at all..work indoors. etc
Add NearMe to the apps
ta |
totalgsm Joined: Jan 12, 2007 Posts: > 500 From: totalgsm.org PM, WWW
We do support it.
@reesy,
Yes it added 'View on Map' to photos geotagged.
Not sure about improvements to GPS as didn't use the phone at all when I got it till it had been debranded. Although I've had no problems with it locking on - used it a few times
'NearMe' application - don't think so. Can't seem to see that in Applications...
boydinator1 Joined: Nov 06, 2008 Posts: 1 PM |
I have the c905 on orange and i have bought 10 credits on davinciteam and i dont know whether to choose the option 'Flash custom software' or 'Software Update DB3210'?
cheers
im trying to debrand my phone by the way
cheers
[ This Message was edited by: boydinator1 on 2008-11-07 17:10 ] |
Select 'Software Update DB3210' to select an unbranded firmware.
mike_hunt Joined: Nov 12, 2008 Posts: 1 PM |
cheers done just this and rebranded my orange c905 |
