Forum > Sony Ericsson / Sony > Software, Firmware and Drivers > Killer_Bunny_Menu_fixed_by_GutZ_Brazilan_Edition
Author Killer_Bunny_Menu_fixed_by_GutZ_Brazilan_Edition
thefabie
K800 Brown
Posted: 2008-08-29 13:42
really luv diz menu.. but brazilan edition..
anyone can change this menu to english version
http://www.4shared.com/file/2[....]y_GutZ__Brazilan_Edition_.html
[ This Message was edited by: thefabie on 2008-08-29 12:54 ]
strizlow800
G900 Brown
Posted: 2008-08-29 13:54
Changing that menu language requires advanced graphics modding and good knowlegde of photoshop or other similar program. It includes a lot of work to adjust and sort the fonts and graphics... Anyway I think it is the PSP menu that appeared on se-nse.com some time ago. I had the same problem, but I had german version. I'm pretty sure I have seen an english one for this menu,
thefabie
K800 Brown
Posted: 2008-08-29 13:56
where can i get the english version? cant find.. help me plz..
strizlow800
G900 Brown
Posted: 2008-08-29 13:57
Search for PSP menu around se-nse.com There should be a link. Or i you can find it at www.topsony.com in downloads section I can help you get it from there...
thefabie
K800 Brown
Posted: 2008-08-29 13:58
same menu? english version?
strizlow800
G900 Brown
Posted: 2008-08-29 14:02
No. Let me do a little search... Will report the result to you if I find something.
thefabie
K800 Brown
Posted: 2008-08-29 14:04
ok.. great.. tq
strizlow800
G900 Brown
Looking for this:
http://rs36.rapidshare.com/files/82786153/psp_menu.zip
thefabie
K800 Brown
Posted: 2008-08-29 14:06
try download n see this menu
--> http://www.4shared.com/file/2[....]y_GutZ__Brazilan_Edition_.html
strizlow800
G900 Brown
Posted: 2008-08-29 14:11
I know it is a bit different, but the main menu icons I gave you are the same...
Just change their file names and use them instead of the ones of your first menu.
thefabie
K800 Brown
Posted: 2008-08-29 14:13
what font this menu use.. i want to make the english version
strizlow800
G900 Brown
Posted: 2008-08-29 14:14
I don't know the font exactly... I think is some version of the Sony Sketch font, but not the original one imho... Not 100% sure though. If you want I can combine the 2 menu icons and make you the english version of the first one you gave me? You will have the english menu icons though.
LOL things got a bit messy here... We would need someone who knows brazilian good to translate the menu... It seems that the whole menu.ml file labels are translated to other languages which makes the usage of the icons from other menu nothing... You will get only the Main Menu translated to english... :S
thefabie
K800 Brown
Posted: 2008-08-29 14:21
ok.. u change this menu to the english version >> http://www.4shared.com/file/2[....]y_GutZ__Brazilan_Edition_.html
tenkiu.. heheh
strizlow800
G900 Brown
Posted: 2008-08-29 14:23
I could but I realised that there are words I don't know and I cannot translate it properly... Better option is searching for english version.
thefabie
K800 Brown
Posted: 2008-08-29 14:24
edit the icon to english too.. tenkiu2.. heheh n u upload okey.. .. u make the english version
