deboopi Joined: Jan 24, 2005 Posts: 21 From: Belgium PM |
I recently bought a HCB-150 bluetooth carkit as a replacement for my HCB-120. Although the HCB-120 was ok I was not so happy with tthe sound quality. The HCB-150 is a lot better for its sound quality, you can also select a number to call on the carkit, it's got all the entries from the connected phone.
I'm due to a second recharge for it and I have the same problem as the previous time.
Yesterday the battery symbol was still looking as it still had 50% of its charge bu this morning nothing happened when turning it on.
So I connected the charger in the car but only the call and reject button and the scroll wheel where lit.
My phone did reconnect to the kit but and that was it.
When calling to the phone nothing was heard on the HCB-150.
So now I removed the kit from y bluetooth devices on the phone and started searching for it on the phone, nothing found.
So I tried turning the damn thing off (this was the first thing I tried) by holding the call and reject button at the same time, nothing happens.
When the battery is charging a symbol should be visible on the display but I cannot see anything.
The first time I experienced this problem I was able to turn it off and the oon again and then everything was OK, but I do not know anymore how I turned it off at that time.
Did anybody experience the same problem and what can you do about it.
I've looked before for a new firmware for the kit but I did not find a thing, I will restart my quest at the SE support forum as the previous time but I must say they are not very responsive.
Can anybody help me out?
regards
[ This Message was edited by: deboopi on 2008-08-14 09:19 ] |
